Sounds like 'I need help with my Phd. 'It is considered polite to introduce yourself first before "I need"
Thanks For Your Feedback Sir,100amps ,6lpm, try a 3mm fillet joint.
It's more useful if you give a clue as to what your doing.
Go to your local BOC stockist as they have these small circular charts on the counters for freeI need Detail theoretical Calculation of TIG welding in following area
Welding Parameter calculation
Gas Flow Calculation
Weld Joint Calculation.
Please suggest.
Regards
Vishnu
Ok. I think I've got an idea of what your looking for Vishnu.Thanks For Your Feedback Sir,
Basically I need information about theoretical calculation for welding parameter of TIG welding.
& then I have to conduct trial with respect to present parameter we are using & compare.
I need this for welding of M.S sheet having thickness ranges from 0.8 mm to 2mm.
Regards
Vishnu
I apologize for the mistake. I should introduce my self prior asking any help.
I am mechanical engineer, working with automobile firm.
I am working on TIG welding analysis & I need guidance from basic calulation of TIG welding.
Sorry again for Mistake.
Regards
Vishnu
First you need to calculate heat input from a given procedure. Amps x volts(Ocv)/travel speed x .8(tig process correction factor)
This will give you a figure in j
The limitation with all manners of welding is heat input. There is only so much the parent material can take before either the mechanicals drop off or in your case with the thin metals you end up through it. Now you also need enough heat to ensure adequate fusion and penetration levels. Regarding
Your joints, material thickness with regard to current levels are usually worked out in two ways.
1) what works in a practical sense
2) how far can it be pushed before the weld strength/toughness drop below acceptable.
Wps is produced on the distructive test results based on what is needed from a weld. It could be purely penetration/fusion levels in which a simple macro test is sufficient. Strength and ductility are tested with face,root and side bend tests. Charpys can be taken anywhere on a weld sample for notch toughness results. So you see the calculations are minimal really as all you need to know is heat input. Then carry out weld samples for testing. The tests that provide the results you want are the ones you record your heat input for because overall it's that heat input level that needs to remain the same for your results to remain the same.
I hope somewhere amongst that post there is some useful info to take away. It's been a while but I remember some stuff from my inspection days.
