evening all
just after a bit of advice if anyone can help
my bandsaw blade decided to break on me the other day so i thought i would have a go at welding it back together. cut the old edges off to make a nice flat joint for a butt weld, cleaned the area to be welded front back and sides.
clamped either side of the joint onto the bench with a peice of copper underneath as a heat sink. tacked it at the top and bottom then welded it up. there was no gap so i didnt use any filler, welded up nicely, turned it over full penetration thought brilliant gave it a bit of a wiggle and snap! the blade snapped again, but not in middle of the weld where i would of expected but to the side and out 45 degrees to the top.
welded it back up again and had the same results
its the standard blade that the saw came with so its not the best anyway, should i take this opportunity to buy a better blade or has anyone got any thoughts or suggestions even just to get my by until the new blade arrives?
tom
tom
