Hello all, new member here :-)
Appologies if this is in the wrong section.
Need a bit of advice on TIG torches.
I have a wp9 valved torch that i used to use with a scratch start inverter setup.
I have just aquired a 200 amp HF set and need a torch for it.
Could i add a switch to the wp9 and use that?
Switch lead kits are available on Ebay for £15 ish
I will be welding 1.5mm wall stainless tube together and also 10mm thick flanges to the tube...i'm fairly new to TIG welding so not sure if the wp9 would be up to the power needed.
Thanks in advance
Martin
Thanks in advance
Martin
