campero2000
New Member
Finally I have finished my water cooler torch, after many tests the procon pump is the way to go. The reservoir is a bit little (3 ltrs) so we will check if it's enough with the radiator. The housing it's from a water purificator, there is a relay controlled by the gas solenoid in the welder ....i think it will be enough, if not I will put a delay relay.
I hope you enjoy........
