Premiershipman
- Isle of Man
If anyone could help with regards to tig brazing copper to copper and copper to brass it would be greatly appreciated.
Currently i am trying to braze 2mm copper into shapes using copper circles and half circles and then brazing on a brass rod to make bubble wands.
I am using Sifsilcopper 968 to braze but i am having trouble getting it to braze without overheating the copper to the point where is starts to melt. I have also tried to braze the brass rod but it ends up leaving a white/yellowy residue without really brazing well.
I have the machine set to about 40 amps and seem to get fairly decent results around 35 amps for the brazing copper to copper but it is hit and miss.
I am using sifsilcopper 968 filler rod which weldability advised to use, but its 1.2mm diameter which i know the diameter is small but its all i have, i could maybe purchase some 2.4mm filler rod if that may improve the situation or would some people suggest using sif bronze no 8 ? Or should I try using copper wire as the filler ?
Thanks for any advice people may have.
Shady
Shady
