Hi Guys! New round here, but thought I would jump in on this one... I know a thing or two about electrics! You will probably find that you could pull 20amps through a 13amp plug with 13amp fuse for quite a while... don't have the disconnection time graph to hand for 13amp fuse, but you will probably find you can pull 20amp for about 600ish seconds... that said, it is a bad idea! The plug and socket have only been designed to supply the 13amp load, while they will be ok with a bit more for a while, they will start to get hot, and could potential catch fire! Much better to get a dedicated supply installed, that is protected with the correct breaker/fuse, and also RCD protected. Something like one of these is what you want: http://www.tlc-direct.co.uk/Products/GW240slash32slash3S.html
Thanks
Paul
PS.... hoping to get my first MIG soon!
Thanks
Paul
