Lufbramatt
- Rochester, Kent UK
Hi all, feel like I'm finally getting somewhere with this. Been learning to join thin metal together (1mm) using the thin metal technique (overlapping tacks) and also plug welds.
Welder is a Portamig 185, argoshield light and 0.6mm wire (came with the machine).
After lots of fiddling and getting stuck for a while with tall welds with inconsistent penetration, I found yesterday that the welds were much flatter and better penetration if I turned the voltage up (setting 6 of 12) and the wire speed down (speed 4 of 10, think the feed is semi-synergic on the Portamig so in theory you can leave it on 5 all the time). This gave a smoother sound too. Resulting welds looked just like the pics in the tutorial.
Previously I had the settings much lower so it seemed counter intuitive to get better results turning the voltage up? am I on the right lines?
