Hi ! Hope you can help ?
I'm trying to use a Thermadyne Thermal Arc Fabricator 360 Mig welder. We bought it at work off Ebay - so no instructions !
The wire in the machine was rusty so I've replaced it with some new Nexus 0.8 mm wire, and fitted a new torch as the old one was minging !
Just one question though - the wire feeder appears to run slowly for about 4 seconds before speeding up ? The unit has a digital wire speed indicator and 2 roller wire feed. When you press the trigger the feeder unit runs at the same speed (regardless of wire feed speed) for about 4 seconds before speeding up to the desired wire speed.
Is this normal (and if so - any idea why ??) or is the unit faulty ? I haven't tried to weld with it yet (need some 0.8 tips) but I suspect it might burn back at first before the wire speed kicks in ?
Any ideas or assistance would be greatly appreciated !
Many thanks,
Garreth.
Many thanks,
Garreth.
