The vertical lines are dirty corona wires and the faintness is either lack of toner or your transfer roller is goosed
Is the toner cartridge a genuine HP or a compatible?The one that prints grey has a fairly full toner. so I guess something more serious is wrong.
So I better get googling corona wires.
(non genuine cartridges) so I no longer use it.My laserjets have software settings so you can change the amount of toner it puts on the paper. Also the toner feed is via a hopper so removing, shaking, and re-fitting the cartridge sometimes helps. I have a colour laser that did the vertical lines, it needed new cartridges and the lines disappeared once they were fitted. Now the colours don't line up though(non genuine cartridges) so I no longer use it.
It is a 2600n and some sort of joint venture with Cannon
I meant the cartridges are hoppers, otherwise no point in shaking them up. There doesn't seem to be a colour miss match procedure, the book says it does it on start up. It is a 2600n and some sort of joint venture with Cannon, a very different set up to my mono HP lasers.
If the cartridge on the 4000 is good then the only other thing it can be is the fuser unit.Genuine toner in the lj 4000, the printer was binned by my sisters office[it was 2years old at the time]
and came with two new toners, I was still on the one it came with after 15 years! but swapped it for a
new one to see if it improved the print, which it didn't. I could never get the density I got with my laserjet 4L.
The colour printer needed a yellow toner. The lines are yellowy green. green+blue?
I put a new yellow in it and it didn't make it any better.
It has lines of toner on the belt thingie, so I cleaned it, closed the door and let it do
it's calibration routine, then opened the door and there are lines of toner on the belt again.
