Bill Edwards
- Scarborough, North Yorkshire
As some may know I'm currently modifying a nice, new 4 roller wire feed unit to run off a cheap 150A welder.
Now, I've just had a thought:
I have two 150a SIP units that have the usual wire feed issues are are essentially scrap - they've been sat for years as a result, but I'm sure the transformer side of things will still be fine.
Could I connect them both together in parellel - just connect the earth leads together and the welding output - and have a welder with 300 amps?
If they were MMA welders on DC I couldn't see any issues with two units giving the same voltage, you'd have double the amps, or the ability to run both machines at a lower setting and have an increased duty cycle.
But MIG seems to vary the voltage rather than the amps and I don't understand how that all works, so what would happen with double amps but the same voltage?
) but it must greatly improve the duty cycle when running at say 150 amps, split between both at half power.
