Kram
- Sussex
Would like opinons of my first alu welds. Aluminium seems much easier than steel
but until today Ive had feed issues. No idea how much gas Ive used up
from 110L bottle. Gas was set between 3-5LPM by pea shooter. Spool gun thread is in Sealey section if anyone interested, I recommend it, should be possible on any cheap mig.
Main difference for alu it needs gravity and torch held above work, otherwise wire balls up and wont jump the arc to the workpeice, looks like poo. Perhaps I need to swap polarity?
Alu doesnt blow holes very easily, but it will sag and bend, penetration is easy, flows much better than steel.
Some welds were black as if no gas or far too much power? but then Id have good welds without any changes, seems random (there was gas).
My 130 mig can blow holes in 2.5mm sheet
then a large blob of molten alu made a hole in my gas hose so I stopped
I will need to weld caps onto the end of 3mm thick, 2.5" square alu tube. They are going to be lipo battery cases for an ebike project
from 110L bottle. Gas was set between 3-5LPM by pea shooter. Spool gun thread is in Sealey section if anyone interested, I recommend it, should be possible on any cheap mig.Main difference for alu it needs gravity and torch held above work, otherwise wire balls up and wont jump the arc to the workpeice, looks like poo. Perhaps I need to swap polarity?
Seriously in my experience (and I haven't done it in a good long while) Ali welds super fast with mig but you need the right set up feed wise and you need to get the right arc to make the weld sound. Good spool gun or the correct rollers etc in a 4 wheel wire feed
