Supposedly a new concept in welding.
A New MIG Welding Machine
Technomig 180 Dual Synergic from Telwin
This is an all NEW way to MIG weld, it's so simple
A Microprocessor controlled MIG-MAG/FLUX/BRAZING inverter welding machine. The Technomig is the perfect solution for a wide range of applications, from maintenance to installation and for welding work in body shops, because of its flexibility and the range of different materials it can weld (steel, stainless steel, aluminium) or braze weld (galvanized sheet).
The fast SYNERGIC adjustment of the welding parameters makes the product very easy to use.
Just set the material thickness and start welding: the intelligent and automatic control of the arc, moment by moment, maintains high welding performance in all working conditions, with different materials and/or gases.
The operator can also intervene manually along the arc length: this adjustment means the weld seam can be modified according to the welder's style.
The machine is lightweight and very compact, the Technomig can be moved around easily in all areas, both indoors and outdoors.
Main features:
polarity change for GAS MIG-MAG/BRAZING welding
synergic adjustment with setting only of the material thickness
fine adjustment of the arc length
10 synergy curves available
compact and light
thermostatic protection
overvoltage, undervoltage, overcurrent protection
motorgenerator (+/- 15%) protection
Main features:
compact and light
