I'll recently bought a secondhand Tecna welder to replace my stolen 7902 handheld welder. I'm having problems understand what the starting setup should be. Its single phase and came with a 16amp plug and a extension to 13amp. Every time I setup it blows the 13amp before I can produce a spot weld. This is odd as my brother saw the welder demoed with the 13amp plug. Does anyone know what I should be setting each of the settings:
PARAMETER RANGE
SQUEEZE 01 - 99 cycles
WELD TIME 01 - 99 cycles
CURRENT 00 - 99 %
HOLD 01 - 99 cycles
OFF TIME 01 - 99 cycles
COMP. OFF / COMP. ON 00 - 01
SINGLE / REPEAT 00 - 01
WELD TIME 2 00 - 99 cycles
CURRENT 2 01 - 99 %
SLOPE 00 - 29 cycles
COLD 01 - 50 cycles
IMPULSE NUMBER 00 - 09
Thanks Dan
PARAMETER RANGE
CURRENT 00 - 99 %
HOLD 01 - 99 cycles
CURRENT 2 01 - 99 %
COLD 01 - 50 cycles
Thanks Dan
