Hi all first post here!
I have the above plasma cutter with built in comp (not the plus model). Don't really know much about these ill describe best i can. Has a strange problem when i first got it it took a while to get the thing working. First after 5 mins the pilot arc started to come then about 5 mins after the full arc came. I then used it for about 5 days on & off it was absolutely fine. Starting strait away. This was about 1 & a half months ago.
Just went to try and use it today - When same thing. Except only get a green glow and a few sparks which i assume is the pilot? arc. Ive tried new genuine TD parts electrode, tip, gas diffuser & shielding cup seem to make little difference. Any idea what could be causing this - the comp runs briefly about 1 sec then cuts out like it did before.
I suspect possible cause to be the air pressure contact/switch is getting very weak or perhaps the machines on it way out? Its an old one built in 00!! (ebay special....)
To aid any responses ive done the below;
I tested the safety contact for the shielding cup which is fine.
Obv the machines on & seems to be functioning.
New consumables fitted.
Cheers!
Cheers!
