hotponyshoes
- Somerset. Uk
So now and again I repair and replace panels on horseboxes/trailers.
We are pretty efficient at doing this now and the one thing holding the jobs up at the moment is waiting for the stickers to arrive to complete the job so I would like to get my own cutter.
The stickers used are the same as the ones used for sign writing on vans etc.
Individual letters cut from self adhesive vinyl
The biggest one I would need would be the word HORSES about 25cm high by 1m wide.
Does anybody have any idea of a good cutter to get?
I would like something as compact as possible as I don't have room for a 48" wide thing on it's own trolley!
I am guessing if I need a 25cm x 100cm sticker I can do it sideways from a roll that's 30cm wide for example?
Other requirements,
Not too flimsy, it will get moved around a bit and put away between uses.
Ideally have some sort of memory card or usb stick slot so it can print from that rather than being connected to a computer all the time.
Handle vinyl mostly but it would also be nice to be able to use the shot-blast template stuff as well.
Aside from recommendations for the cutter, what else do I need?
The stickers I use now are only cut through the vinyl and are on a layer of backing paper. They have a clear film over the top to homd the letters in place when the backing is removed. This is what I would like to achieve.
I presume the vinyl comes on a roll with the backing paper attached and I just set the blade depth to suit?
Then run it through the cutter,
Then pick out the bits I don't want and apply the clear holding film manually?
So I need some tweezers etc. to pick out the unwanted pieces
How do I apply the top film? Do I need a jig to align it? Some sort of roller to get it flat?
Or are there cutters available that hold a film roll and apply it for me?
TIA!
Other requirements,
TIA!
