julianthegypsy
- Cirencester
Hope this is in the right place. I have a swp211 that I picked up off evilbay allegedly in working condition...well it lights up but pull the trigger and nothing happens. Pulled the euro connector off and one of the pins was jammed. Result! Freed it up, pulled the trigger and ...nothing. Took the side off and discovered two wires that had been rubbed bare on the edgeof the transformer and obviously shorting. Go me! Taped them up and routed them clear of the transformer. Switched on again, pulled trigger and...nothing. Another look around and realised that one of the diodes on the rectifier is blown, as in the solid wire has burnt like a piece of fuse wire.
Now. Steve at weldequip was most helpful and has quoted me £60 for a new rectifier which seems reasonable, but my question is, what would cause it to blow in the first place?
The unit actually looks in nice clean condition but its going to take a fair bit of work as well as the sixty quid to fit the rectifier and I'm loathe to shell out then find it still doesn't work or blows up again ten minutes later. All advice gratefully received!
