Kent
- Bowland, Lanacshire,UK
Has anyone done the above? I moved into a my first house 18 months ago and it has oil central heating with a 1000l tank. I plan on changing the boiler for various reasons and was seeing if I would be better of with lpg. After calling calor gas it seems I cannot have a bulk tank due to my garden being to small, you need a 3 metre area around the tank ( my neighbour has a bulk tank which is next to the garage?) The only option I have is to have 4 x 47kg bottles. Calor told me that the bottles are £50 each and in the winter months 2 bottles will last 3 weeks then it has an auto change over valve to the next two bottles. Does 3 weeks seem about right? I have A 2 bed with 8 radiators with the heating on for 4 hours every evening at the moment? Seems like it's going to be expensive, £100 every 3 weeks and the hassle is calling regular to arange delivery.
So far I have only needed to order oil twice, 500 litre a time at around £300 a time, admitadly I have not had the heating on as much as I would like due to faults with the boiler, trying to nurse it till I could afford a replacement I would use more oil on a fully working boiler.
The guy from calor Was saying lpg was more efficient and would heat up faster so I use less? it seems unless I had a large bulk tank I would be better off with oil?
DON'T DO IT! LPG requires oil supply to manufacture, from a bottled supply it will freeze and fail to empty a bottle. Per unit of heat fuel oil is now compeating with natural mains gas and is set to better it shortly. The only downside is oil boilers are basic yet I should say that's a positive plus in "fix ye not" modern throw away times
