stumpypower
swaging/bead rolling sheet steel can it be done if there is a ten mm lip down its length 1 side and a 10mm lip across the rear edge or can it only be done on a flat sheet with the lips being bent afterwards?
reason i ask i have made new floor pans from 1.2mm thick sheet steel there is a lip across the rear 300mm wide 10mm high and down its length on the outside 1300mm long where its to be welded in to place but i have found somewhere local that can swage it for me but the lips are already bent can it still be swaged
