madkayaker
Pro sparkey Pro Welder
The damage of the Neutral leaking to earth is if the conductor was to fail the all the current would flow to earth and could raise the potential (and there for voltage between earth and the ground if that makes sense!) also the earth could provide a lower resistance return path then the neutral and there for would take all the current with the above effect. an RCD will trip if neutral and cpc are shorted always a good one to frighten apprentices with when the cut the cable (that is de-energised) and the lights go out!
