Long story short - one of my rear spring pans cracked this morning and fouled the wheel. Surface corrosion has weakened the outside of the pressed steel member, and the force of the spring has deformed it slightly. I managed to hammer it back to shape and drive very slowly 800 yards to a safe place. Planning to get the car recovered home. Question is - would it be safe to weld the spring pan? I was thinking grind & wire brush cup all the rust out of it, treat, and then plate round the weakened areas with 1.6mm or 2mm plate. Is that realistic?
Also, to add to my joys, I picked at an area of loose underseal, and discovered a spot of further corrosion above the top spring mount. It's not too bad, and a small patch will sort it. Around the top and sides I will lap and seam weld. The lower edge is a thick return piece from the chassis leg - I was thinking of plug welding this every half inch or so. Or should I seam it all round?
) and I think I'll have a closer look now, so I have a vested interest in you proving a decent repair
