Noods
- Ipswich
Hi All..
Pleased to update and say ... The Suns been out I've a couple of days off, for a change, and my mild steel welding is great...
I thought it time to move onwards and upwards..I went to a place ( nameless ) who specialise in marine SS welding, as they offered me some offcuts at a cheap rate.. While there knowing I had no ss rod at NöÔDLe Towers, I asked what rod do they use and can I buy a few lengths... They abliged, and gave me.. 1.6mm ER309L SS filler rod? Now speaking with Richard I know 308L rod is one I should think about buying, but 309? I looked on the forum ss section at a chart on there and it is mentioned.. I've got a supply of marine grade stainless tube but I can't see any numbers on it as they are off cuts... Having said that, early days but tried it tonight and it went very well ish.. My only concern was the welds although neat ish were a darkish grey colour.. I was on 2mm and 4mm ss stock.. I varied the amps at between 35 and 50amps thinking it might be too much heat! I had no purge as its only practice joints, 1.6 red tip Thor tungsten DC with pure argon set at 4 with a gas lens fitted.. Perhaps I'm just expecting too much?
Also I welded a 32mm tube into a hole in a 50mm tube which went well, is that joint I've created an inner joint?
If you imagine I've now welded two pieces into each other to form a capital T...
Many thanks .. Sorry forgot to get pics but need to buy some rod ASAP now, just which one?
Hugs .. Barking NöÔDs X
