cantfindausername
weld? blow holes you mean!
Hi all,
The garage and area that I'm likely to do work on my car is quite a way from the power supply in the house. I've got a Clarke 160TE which is ok to run on a 13amp supply, but wondered if I would be ok running it on a 50m extension reel?
I wont be doing heavy welds. Maybe a bit of exhaust work. Nothing heavier than 3mm max. Probaly normally inthe region of 1-2mm mild steel.
Thanks,
Ant
Thanks,
Ant
