We've a posher version of that at work, an Italian thing about £250 you charge it up with a compressor, creating a vacuum, and it sucks your oil out, works a treat.I use this one for my lawn mower and cars. Changing your own engine oil is so simple with these.
This one really sucks
bought one of those donkeys years ago due to mangled sump plug on a mk1 iveco daily when I bought it , still in use , good tool.Clear bit of tubing....how i decanted 20 litre tub into a jug
Yep I can recommend this one too!I use this one for my lawn mower and cars. Changing your own engine oil is so simple with these.
I've got one and it's pretty good but the tubes are too large to fit down the surf's dipstick tube, I think I heard @8ob had found something with thin tubes?Lidl do a 12v oil/fluid transfer pump for not a lot of dollar . It's got a thin pipe for sticking down your dipstick
Mine worked fine on my old 2nd Gen Surf, but while the tubes fit down my 3rd Gen's dipstick tube, there's a narrow obstruction near the sump. I can get a bit of 4mm pneumatic tube through, but at that point, removing the sump plug is much quicker!I've got one and it's pretty good but the tubes are too large to fit down the surf's dipstick tube
Tell us why draining the oil from the drain plug once a year needs lots of £ spending on it? Or is there no drain plug?
Exactly that,there isn’t one.Tell us why draining the oil from the drain plug once a year needs lots of £ spending on it? Or is there no drain plug?
