Bill Edwards
- Scarborough, North Yorkshire
I've got a repair job where a stub axle has snapped off. It's a rake for rowing up grass, powered by a tractor.
The design of it seems to be to have a piece of plate (approx 10mm thick) welded onto a piece of box section frame. The plate has a hole in and I expect the stub axle was welded from the rear.
It's here that it has snapped, and the rust marks show it's been going for some time.
I'm intending to buy a piece of 25mm round stock, cut off the plate, weld the round stock on from the rear again and weld the plate back on. Or, better yet, if I'm able drill a hole right through the box section and make a better job of it.
What should the steel be for the round stock? Will ordinary stuff suffice, or should it be something like EN16?
If it fell off it wouldn't be dangerous, but naturally I need the job to be right as it's for somebody else. Perhaps anything will be strong enough, but before ordering it would be good to have some thoughts on it.
