I have corrected vision, but a large auto-darkening helmet makes it hard to get close enough to focus on the fine line between two panels.
Welding 0.8mm patch to 0.7mm wheel arch (0.62mm in places re stretched) was hard. Had to use multiple tacks to build up weld thickness, then grind most of it off and run 1-inch beads to get a nice 55-above 45-below bead (fussy I know on auto metal, but it is the principle!). On another place I simply welded again from the other side (below) and pushed the wire speed up.
Anyone tried auto-darkening goggles and a "fire flash hood" re sparks & UV?
