Merry Christmas!
I need some help with strength/properties of parallel Flange Channel steel section.
I am building a new 1.5 (Metric) tonne capacity tipping body for a Transit.
Standard tipper body design has a captive 3m long ladder frame fixed to the chassis and a 3.3m long tipping frame which sits on top of it and tips. The two main beams for the captive and the two for the tipping frames are usually 80x40x3.2mm Rectangular Hollow Section (RHS) on edge.
In an effort to reduce loading height I am thinking about replacing the existing tipper beams with parallel flange channel ('PFC' or 'C section') laid on its side (So its n-section) and overlaps the captive RHS frame. There are a few extra mods, gussets and flanges etc but the crux of the thing is this:
I'm worried about the strength of the new two main tipper framing beams.
The existing 3.3m long 80mm x 40mm x 3.2mm Rectangular Hollow Section beams which are laid on their stronger (40mm) x-axis, would be replaced with 125mm x 65mm Parallel Flange Channel (PFC) laid on the weaker y-axis, in an inverted 'U' or 'n' fashion.
The thickness of the web of the PFC is 5.5mm and both the parellel flanges are 9.5mm.
The Second moment of area of the y axis of the PFC is 80 cm4, when used as n-section (Stronger x-axis, when used as C section, is 483 cm4)
The Second Moment of Area of the 80 x 40 x 3.2mm box section on the x axis is 57.2 cm4, when used on edge (Weaker y-axis is 18.9 cm4, when used flat)
So can I compare the valves of 57.2cm4 of the RHS on edge to 80cm4 of the PFC used as n-section directly and assume the PFC will be strong enough or is there more to it than that?
As I'm effectively using the C section PFC out of its design parameters, I don't know if the new 'n' beams be strong enough, or be as strong as the original Rectangular hollow section? I'm tempted to destructive test some RHS and some PFS sections on a loading bay, with a 3 tonne minidigger sat on them and load them up with two tonne of sand using dumpy bags.
Anybody know anything about strength of materials as my brain is feeling liquidized?
