Memmeddu
- Italia Sardegna
Hi everyone
Last week I've completed the assembly of my MS361 to upload the restoration video.
It wasn't idling properly and kinda flooding.
I've thought about a carburetor problem and I was right.
Today I've opened the carb on the mitering diaphragm side check the needle valve lever and it was little high I've adjusted it, reassembled.
I've set the jets at Stihl recommended settings so 1/8L and 3/4H as it still has the limiter caps installed
Started almost instantly.
Held idle great, great or better perfect Tigger response running up to limiter instantly.
The engine revs up to 13800RPMs then the limiter cuts out backfiring shutting flames out of the exhaust
I've had the tachometer connected so I've shut it off for picking up a screwdriver to set the idle.
Now Stihl says 14000 maximum RPM , I'd like to set it at 12800 because I don't like small engine to run that lean .
I've attempted to restart but nothing to do.
I'm suspecting the ignition module is faulty because it pops and bangs constantly over 8000 RPMs.
And I remember it was a common fault
But might be the sparkplug too.
Have you got any similar experience? Or bit of advice
