christofloffer
if it says 'dont', then it must be fun!
- shropshire, UK
not been on here for a while as my health put an almost complete stop to welding for a while.
i finally made the step up to gas, got a 5kg reel of sif wire, got a BOC account and i have a Y-sized bottle of argoshield universal. got a good regulator and flow meter (pea shooter type). also got a adaptor pipe to knock it down to a push in pipe so its not stretching anything or going on its side when on the floor.
i took the plunge as i have some major structural work to do on my land rover and i wasnt keen on trusting gasless. i needed to up my game with it anyway. so i had a little practice with some thin scrap i had kicking around and then found out some thicker stuff to work on. the stuff in the photo's is around the same kind of thickness as the chassis. i am practicing vertical upwards as that is the really important part of the job. i was trying to use the triangular movement thing as that seemed to be recommended.
first attempt:
second attempt:
third attempt:
the welds are pretty strong. i stuck them in the vice and ragged them around but the metal was bending around the weld. i jammed a cold chisel behind them too and smacked it about and again it was the surrounding metal that was bending. so it seems to be holding.
i am getting this light brown deposit, which you can see in the photo's, is that down to the gas? too high/low flow rate maybe? they were all continuous beads rather than a stack of tacks, figured it was better to keep the heat moving if possible as the thickness could take it.
any additional pointers would be great as i want to get this right. i am not afraid of the work but i want to be sure of the welds.
p.s the bits to the right of the main bit in the first photo are just a few warm ups and setting experiments, its the corners that i am working on.
first attempt:
second attempt:
third attempt:
