Hi, I need to get a piece of steel plate cut to cover part of my workbench for welding on, about 3ft x 2ft. Question is, what thickness should I get? The workbench is solid wood so the steel will be completely supported, so what is the minimum thickness I can use that won't distort from the heat? I was thinking 3mm would be ok, but would 2mm be thick enough? Thanks for any ideas.
