Depends how much 'bend' or deflection is acceptable. A bend could be anything from less than a mm say, to bent like a hairpin. Then theres elastic and plastic deformation.
Bright bar, or BDMS is tougher than ordinary mild steel.
1kg - 9.81 Newtons, so very roughly speaking your wanting to put the equivalent of 1997 kg mass on it. If it's applied as a point load at the centre of a 1.4 length its going to bend double unless the ends are restrained, but even then its going to bend/get close to snapping.
What are you planning?
I have spoke to an engineer and he recommends using steel with a yield strength of 391Mpa. Does anyone know of a steel that satisfies this requirement?
The grades these days signify the yield stress, so S235 has a min yield of 235N/mm2, the next grades are S275, S355 and S420. Therfore you will need S420. As far as I know its not that common. Could you use a thicker section of S355 as its probably more common.
