- England
Had a few issues with a forklift starting and rapid battery drain.
Putting a tester across a new battery, 12.6v.
Engine starts no problem at all. No change in voltage after running, I'd expect to see 13-14v...no difference at any rpm. Put tester across alternator wire and body, all I get is battery voltage. Points me to a dead alternator.
Ran a tester between live terminal and starter connection, when cranking, get about 0.3v.
Ran a tester between negative terminal and clean point on engine block, I can get about 6/7v. When cranking.... nothing otherwise. I shouldn't have hardly anything should I?
Is that voltage a likely symptom of the dead alternator?
