pondy
- chedburgh, suffolk. uk
hi, small question, making a battery box to go on my race quad, i have one now but changing to a larger battery so need to make anoyther box. i brought the one im running now, the main box is made from 1.5mm stainless and has been tig welded together, i want to make mine for mild steel and mig weld it, should i be worried about strengh, should the material be thicker? the battery weights about 15kg and the bike takes some abuse, has 3 mounts that will be 3mm thick steel
sam
sam
the ones in your motor are presed tin sh ./././te and last the life of the car virtualy.the battery shouldnt leak otherwise its knacked . if its going to get a hammering make it slightly larger and rubber line it
