- England
The only problem is you need to find someone with a magnetic table fitted, the 3mm needs pulling down flat.
Don't try too hard with that mind, probably a waste of time
spent half the day on the phone trying to find an easier / cheaper solutions but with no luck so thrown it back to the client to see what they want to do. Thanks for all the suggestions gents.
1mm slitting saw in a horizontal mill?
Ive seen offcuts of plate like that on a job sometime ago, pretty sure its done on a shapper sort of affair setup, the cutter just ploughs it away, rather than using a rotating cutter.
