What sort of boiler? Size, pressure, steam conditions, fuel etc.?
What equipment have you got? rollers, positioner?
120 psi? That's little baby stuff. Ok, there can be a lot of volume and heat behind that in a boiler, so still potentially dangerous, but it's that not far from what we see in a typical compressed air circuit. We're running 400 bar in the hydraulic circuits at work (that's 4 Km of head, if you imagine a hose pointing straight up), with, as far as I know, no safety design, manufacture or inspection regime, coded by law.
Sounds like a lot of out-datedness going on in the legal system. There's a surprise.
so your causing trouble as normal. does seam a bit strange as SS is used for steam pipe on subs etc
Oh yes, lots of danger, if a vessel ruptures the superheated water expands about 1000 times, its more destructive than gunpowder
Who me.
It does seem absurd that industrially, the technology exists world wide using higher temps & pressures but a commercially made model boiler is deemed safe throughout the EU, except the UK(Stainless was invented in Sheffield)
Hi Chris,Hi Jugs,
SS is not used in UK because there is no test protocol for completed model boilers. As far as I am aware this is being looked at by the ME Liaison Group. The most recent info I have came from the National Boiler Seminar 2010.
Section 3 of the current ME test code says that SS boilers shall not be tested, however that said there is no reason why you could not get it tested commercially. But be aware that you will probably be drawn into Design Verification and have to provide calculations and drawings. You also could not use a recognised design where SS was not used.
You could use a SS design from eu or Australia and have it tested commercially under full PSSR 2000 regulations. Don't forget to take out a second mortgage!
If you really want to follow this up talk to Royal & Sun Alliance Engineering, these are the guys who decide what is insurable and what is not.
Chris.
The Boiler test group has rqusted that all comunications with RSAE go via the groupIf you really want to follow this up talk to Royal & Sun Alliance Engineering, these are the guys who decide what is insurable and what is not.
All approaches to RSA, BIS, etc. should be through the boiler sub-committee
John,
You may find this interesting, a project for a 71/4 Darjeeling with a SS boiler, with some info on the Part 4 code.
http://sonadaworks.com/
Are you an active ME? You mentioned the 71/4 AGM, do you go? This years is very local to me, hope to have my 71/4 DeWinton by then.
Regards,
Chris.
Are small boilers not ran under quite a few dispensations anyhow? ie club inspectors, boilers running with history's, visual inspections and hydraulic testing only etc etc the list goes on..
My point being rocking the apple cart could make hobby boilers be treated the same as there large counterparts, and its possible that clubs for insurance may need to have S/S boilers tested to commercial standards......
Whats the problem with a steel boiler anyhow?
