Could always knock a sample out and see how it goes. People seem more inclined to spend money when they can see your actual work rather than a stock photo.
Offer custom ones. You can charge more for all the f’kin about.
Try and roll a cylinder and put a rim on. Like a upside down top hat? Mrs79 has got me making some like that
you never saw any catering equipment made from that stuffI would make them smaller so they can fit in a car for punters to pick them up, do the corners out of brass/copper and extend them down for legs to loose the wheels so it doesnt look like its come out of a modern industrial food factory?
CorrectI would make them smaller so they can fit in a car for punters to pick them up, do the corners out of brass/copper and extend them down for legs to loose the wheels so it doesnt look like its come out of a modern industrial food factory?
from my experience in the UK the extra bit of heat helps the plantsWouldn't the planter heat up during the summer thus kill the plants? Good luck with whatever you decide to do with it though.
from my experience in the UK the extra bit of heat helps the plants in th
In that case I personally would make a bunch of window sill planters, easier for customers to collect.from my experience in the UK the extra bit of heat helps the plants
theres actually very little welding in it, the ends are folded too and are bonded on with just a few tacs to help assembly and the castors are welded on so there are no bolt holes to seal, any welding is fairly easily done with a 2.5mm stainless stick.Never seen anything like that. How does it weld?
