brewdexta
The biggest tool in the box
- UK
I usually get my steel from K-Steels as they are close by, but their stainless prices aren't on the standard price list, quotation only, so I though I would ask for some guide prices and favourite stockists before I ask for a quote.
I'm making some manhole covers for a foot traffic only patio. I have an underground tank to hold spring water. It will be paved using "Indian tiles" which are basically sandstone flags, max depth is 50mm. I will be setting them in an epoxy resin in the cover, I've done this before with a galv cover over the borehole, that takes vehicle traffic too and after 10 years it hasn't shifted. The cover will be a tray made from stainless sheet, bent up on each side and welded, and a threaded key hole welded into each corner so I can screw a hook in on the rare occasion I need to get into the tank.
The cover will sit in a SS angle frame. 50 x 50 will do as I will select flags <50mm deep, you usually get them ranging from 35 to 50 deep.
I'm not using a standard galv cover this time as the size is not standard, plus I have a decent TIG and I need to use it more
I thought I would explain the use a bit as people are bound to ask, however all I need is typical costs of 50mm SS angle and say 2mm sheet from normal suppliers, not ebay prices
