StainlessBloke
Stailess Bloke, what exactly is electropolishing?
Electropolishing is a method of treating stainless steel (and some other metals) to ensure that the surface is consistent and free of contamination. If you think of the process as a reversal of electroplating then you won't be too far from the truth. Basically, the part to be polished is immersed in a bath of electrolyte (a blend of acids) where it acts as the anode. The tank being used has cathodes around its perimeter and an electrical current is passed through the solution causing the acids to remove a very, very small layer of metal from the surface of the part.
This is the critical difference between EP and a manual polishing process - whereas manually, what is occuring is a 'folding over' of the 'peaks' on the substrates surface, EP is actually removing these peaks. Thus, when you manually polish, dirt and contaminants will as part of the process, become trapped under these folded peaks - this is not the case with EP.
This isn't a criticism of manual polishing however: this process can produce a shinier finish than EP can achieve and it is fine for a lot of work. But where the surface cleanliness is absolutely critical, as a rule of thumb, it's better to opt for EP - hence it's often used in medical components. It can also be a lot, lot quicker than a manual process too on large surface areas. I think it's fair to say that for the majority of purposes, EP is used as tool to aid corrosion resistance and dirt entrapment - the fact that it makes a lot of components 'bright and shiny' is a secondary effect.
One other thing to bear in mind though - because EP removes a layer of metal, if you have marks, gouges or deep scratches on the surface then the polishing process won't help them; generally it will make them look worse. Again though, this is a generalisation and not always the case.
Hope you find this helpful mate!
