Stereophoney
Welding Novice Grinding Expert !
Just a couple of questions regarding the above
I've been messing about with some 1mm sheet with my clarke 105en on the lowest setting, however when i attempt to tack weld a butt joint i'm often getting little penetration so when i make a pass i end up with a cold joint
My question is this, should i be upping the power for the tack then back to the low setting ?
Also when i plug weld should i again up the power to the next setting to get good penetration of the back sheet ?
Any advice would be greatly recieved
Also before anyone shouts at me i have read the guides but power isn't really mentioned
