I need to fabricate a wedge shaped packing piece to compensate for a 52 mm difference in height from one side to the other of my 9 foot wide roller shutter door (concrete slab was laid to a fall as intended as a yard but now a building)
The bottom bar of the shutter is 75 mm wide and takes a rubber slide on seal so easiest solution is two overlapping Tee Bars fixed together by through bolts with the Tees set at the desired angle - bolt the upper one to the base of the shutter & job done . . . BUT . . I can't find a source of 75 x 50 x 6 mm Tee bar
I could fabricate something from plate but the chance of me keeping it straight is low!
Any suggestions of a source?
