True but most are, Amazon has some advantages. Have a good idea of prices and buy else where if its expensive.Yep it’s really easy
Stop using Amazon as they are an awful company
Is it possible to sort order an Amazon search.
I can't stand price gouging but this is daylight robbery.View attachment 346095
Why?Yep it’s really easy
Sadly for some items there is just one choice.Yep it’s really easy
vw passat b6 rear brake motor plug connectorCan you link the item or search and tell us what it is/for, I can have a look.
It's not.https://www.3waycomponents.co.uk/Ca...rs/4.8mm-VAG/VW-Audi-VAG-4.8mm-Connector-Kits
This may be the correct one, if not find it from a proper supplier that specialises in automotive connectors.
Is it?Amazon search results are totally useless. Try going on amazon.co.uk and searching for quite a specific item like "honda eu22i generator" without the quotes.
Far better to use a search engine, and adding amazon to the search terms.
Not the same one mate...I bought the same one from eBay ….it even came with the sensor , it binned thst as it was about 8 degrees out . I only wanted the lead .£12 all in
VW AUDI EXTERNAL AIR AMBIENT TEMPERATURE TEMP SENSOR WITH CONNECTOR AND WIRES | eBay UK
VW AUDI EXTERNAL AIR AMBIENT TEMP SENSOR. TEMPERATURE SENSOR WITH CONNECTOR AND WIRES. colour wires may differ. Fit for Audi A3 2006-2009. Fit for Audi A4 Base 2005-2008. Fit for Audi A4 Cabriolet 2003-2004.www.ebay.co.uk
Well no but it does confirms what I find.I've mentioned it before but i find that amazon rarely brings anything relevant up in a search and if it does there are only one or two choices. Search on ebay and there will be hundreds. I just dont use amazon as a result.
Anyway, that doesnt help the OP but gets it off my chest![]()
Just thickos immediately jumping to the wrong conclusion. That's why some ebayer put the out-of-stock items up to £800 for a pair of gloves.On a couple of occasions I ran out of stock so rather than end the listings I just put the price up to £99 a box.
The amount of hate mail I got was unbelievable, some of it was pretty nasty and if I was the sort of person that got bothered by stuff like that it could have been pretty upsetting!
