I've been out this afternoon having a practice and this is how it's looking. I'm still only using co2 at the moment but I'm hoping to get the argon/co2 mix soon. I used the pulsing method as it's only 1.2mm thick steel and I have 0.8 wire. I also used a piece of flattened copper tube behind what I was welding.
Anyway please give me your honest input........
And an earlier butt weld without using the pulsing method. I also think I didn't have the settings quite right for these either.
,I wouldn't grind the edge of clean plate ,but would wipe it to remove oil etc ,"hot rolled" or "black" steel etc does require the millscale being removed for good welds .....You would probably find your settings are ok if you weren't welding on a bench ,as you have a huge heatsink drawing the heat away from the weld....try tacking up on the bench then welding with the plate unsupported ,it will weld differently and be closer to car welding ....whilst the copper backing strip is very useful don't rely on it as often on a car you can't get to the rear of the welds...so as your confidence builds practise on unsupported plates without the heatsink ,it will help you in the "real" world...........By the way, I've used co2 for years on cars,always pulsed to minimise distortion, and see no reason to change as I grind most of the visible weld away anyway,if my work was fabricating where the welds are visible or thick enough to perform proper runs, then I would spend the extra on argon mix,
,are you using disposables?....
) to build a rhythm.....1-2-zap or 1-2-3-zap.....whatever suits your set up and style......
