Am rebuilding an Octagonal summer house in my mums garden and have a slight problem.
It's being re-assembled on a base topped with concrete slabs layed on concrete. I was being helped by a guy with building the base and as it happened he layed the slabs, a while ago now, when I wasn't there.
Now I come to look at them in detail they haven't been layed very level ! The surface undulates by about as much as 3/4" !
As we want to improve the summer house this time I am putting in a floor, made from 20mm shuttering board, this will need joists which will be resting on the slabs, which aren't level !! And there is my problem, how to create a level surface for the joists to rest on.
One idea I have is to lay bricks on the slabs in short runs of 2 or 3 to act as supports for the joists. They could be levelled up with mortar ? Would that work ok ? Although there is little load on the floor I'm a bit concerned that the mortar may break up over time and the joists would lose the support.
The only other solution I've come up with is to lay the joists with a slight gap under them and cut packing to suit. Time consuming that one though !
Another issue I'd appreciate advice on please, originally the structure was just resting on a hardwood plinth around the edge, this has started to rot. This time I'm going to use a course of bricks to act as the plinth, what is the best mortar / cement to use to prevent the bricks loosening over time ? It will be a single course layed directly on the slabs.
