david aldridge
New Member
- england devon
I have trying to do some fillet welds to make a tee joint and its not going well . I am doing it with 2mm plate . the setting are fine when I do a butt joint on the plate doesn't blow threw and have good penetration. but as soon as I try the tee it becomes blobs and then blows threw plus I even had the wire burn back and melt the nozzle . can anyone explain to me how and where I point the torch to on the metal . (ei deep in the corner or to the top metal or bottom and do you point it in from the top or more from the side and do you pull the weld or push it away ) . all advice welcome . I have only been learning a couple of weeks on off
