It was about 8 degrees last night no current draw at all when parked as everything connected to it is offHow cold is it at night ?
Any current draw on the battery ?
Battery is 18 months oldBatteries are crapper when it's cold, could explain it ? And obviously don't solar charge overnight.
How olds the battery ?
That's all I can think of.
Have you put an ampimetric clamp on the cables, to make sure there's no draw on the battery ?Battery is 18 months old
I will try to get some figures this weekWhat's the battery voltage first thing in the morning? The voltage will have dropped quite a bit from being at the "fully charged" voltage of 13.8-14.2V, and more likely to be around the 12.5-12.8V mark. It will still be fully charged, but the controller's capacity calculation will use this lower voltage as its basis. The charge state value should rise rapidly, once the sun gets on the panel. A better way to get a real measure the charge state, would be to measure Ahr in and Ahr out (Amp hours, that is) and resetting the figure every time the battery reaches 100%, or to measure the battery voltage after putting in a net charging current, limited to about 1-2 A (depending on battery capacity), for maybe 10 minutes, or so.
