Do a back of the envelope calculation. Think you might find it'd take a long time to pay back a £400?? Heater. Oil at old prices used to work out at about 6ppkwh. You get about the same for export if you're on the octopus agile tarriff.
Even if you don't get anything for export, it's hard to justify. Worth messing about with second hand stuff and some cheap relays but a bigger upfront cost would put most off in what is not a huge market anyway.
If you have wet heating anyway, a thermal store is the way to go.
Alternatively, if you have anything that can only use proper 220v AC, if you can get that to come on only when it's sunny to displace ~15ppkwh electric, there are bigger savings.
You can get alternative diverters like your (iboost?) That fire a relay if export exceeds a set value. Good for air conditioners dehumidifiers, pumps, motors, electronics etc.
Consider putting fridges/freezers on a smart plug so they turn off for a few hours in the morning/evening and push their usage into middle of day and off-peak nighttime.
If you're really keen on utilising own generation and not too worried about the economics, battery storage might be worth looking into.
P.S; I'm not anti your idea. I currently have 3x diverters and a combination of heat loads which all work quite nicely.
Well thought out answer - thanks. Heating water has to be the biggest cost for a family with small children, so that has been my focus. Once that has been achieved I may look at fridge freezer timer, but battery system is a big step and with stuff that has a finite life - but as you say maybe worth doing the numbers. The G'ment has started the export payment scheme, but that varies depending on supplier. I will cary on with trying to get a response from Dimplex, who knows, they may send me a unit for experimentation.
