brightspark
- yarm stockton on tees
yep thats all; it does. both ways soften it after heating to cherry redThe only difference that I've noticed is that most of the scale tends to fall off when quenched.
Yes, and if it helps convince yourself, bend a piece of 1/8" round in your hands, then bend it straight again, the first bend hardens the steel slightly so the second bend forms either side of it, so rather than getting a nice straight rod back, you get a wavy piece of scrap.It is not something I have ever considered, but can you work harden mild (non-carbon) steel?
When I was at school, in metalwork we made some copper bowls, we quenched them in sulphuric acid to anneal & clean the copper, then buffed them on an industrial buffer. This was in 1962ish, can you imagine that being allowed for 12 year olds today! Still got the bowl.
Mild steel isn't hardenable there isn't enough carbon in it. Work hardening mild steel and copper just makes it less ductile, resulting in tears and tears when shaping sheet steel or copper if you don't anneal regularly.This is quite clear from the two usual types of mild steel bar/sheet - hot-rolled and cold-rolled.
Cold-rolled is merely hot rolled steel that has been further rolled (worked) while cold. Both strength and hardness of the cold-rolled product are improved over the hot-rolled. But in terms of is it worth it? Probably not really, unless one is not going to machine it further.![]()
I wondered the same thing as the new pack of washers I got were distincly hard , so aneal as I use.Does that not just mean that the manufacturers have not annealed them fully, or that they're a copper alloy rather than pure copper?
We had a brilliant metallurgy lecturer when I was at college who explained crystal structure, grain boundaries and dislocations perfectly for all us oiks. I remember he had a big board with loads of small ball bearings he used to demonstrate how the lattice structures would align in patches, meeting up with another patch that was aligned in a different direction. He had loads of anecdotes to show how all this applied to real life.The hardness and ductility of a pure metal depends on the size of the "grains" in the metal (areas of semi ordered crystal structure). Heating causes the grains to merge together and grow, making the metal more ductile and softer. Working the metal causes the grains to divide and you get a finer grain structure which makes the metal harder and less ductile - work hardening.
