Kram
- Sussex
I've been looking at small baby wood chippers. They generally use the gx200-gx460 clone engines but most are under powered. This sort of thing
The bigger machines use V twin engines, but too heavy for my use. Weight is a bit of a problem as I will need to move it by myself, so I'm going for the 460cc I think, possinly the one I linked with an engine swap. There is a larger 15hp version, but that also has a larger, double weight drum unit, with expensive 250mm blades. I'm wanting the smaller, lighter 150mm blade version.
I know the engines are also used for gocarts and it seems they can replace nearly all the parts to get a higher revving, decently powerful engine.
Does anywhere sell that as a kit or as a complete engine?
I'm looking to near double the rpm from 3k to 6k, if possible. That might sound like a lot, but small motorcycle engines will run at that quite happily all day long, provided they are cooled adequately.
I'm aware the conrod and flywheels are weak and can let go, generally prevented by weak cam springs and valve float. Cam shaft no good at higher speeds..
Rotatech 7HP Petrol Wood Chipper 100mm Heavy Duty Garden Shredder Mulcher – Self-Feeding Chipper for Branches up to 4 Inches : Amazon.co.uk: Garden
www.amazon.co.uk
