chunkolini
celebrity artiste
- Swansea
I have a job coming in making some large garden screens for a guy in London. The screens are t measure 1.65x 2.4m. I am going to have them mounted onto poles concreted into the ground. There are three screens, the middle one will share a mounting pole with the two outer ones, so four poles in all.
The screens will bolt onto tabs welded onto the screens, using M10 bolts. I can see that getting everything exactly straight prior to bolting the ecreens being a massive problem.
I figure having the holes slotted; horizontally on the poles and vertically on the screens would give a bit of leaway for installation. How do I slot the holes? Or I am I being too clever? slotting them does give Me a bit of leaway as well.
Is this what I would use to make the holes slotted?http://www.axminster.co.uk/axminster-axminster-bull-nose-slot-drills-prod22805/ I have a cheap cross vice on my pillar drill which might help. Or do I just drill a pair of overlapping holes and grind them out.
I could get the contractor to assemble the screens before installing them he says while typing this out. But slotted holes will be an asset somewhere along the line.
Chunko'.
Chunko'.
