Piero
- Uk
Hi Guys
I am referbing a Edwards 4 foot 2inch (rolls) slip roller
two things need my attention,
both the pinch adjusting bolts are seezed, the thred depth must be an inch and a half,
they are both solid,
they are obviously still attached to the slip roller and drilling is NOT some thing I want to try.
I am limited to heat, only a gas plumbers torch to hand.
any ideas on what to do?????
secondly
the lower roller, (the one that slips) has a cam type locking bearing on one side, and a half bearing on the other, both cast alloy, rubbish alloy,
they are both split and really need replacing.
I would be a little weary of the solder type alloy weld, as they will have to stand up to a lot of pressure.
I have found a place called kee,
http://www.kee.co.uk/default.php?page=machines&machine=slip
who can make me two out of solid stock.
A little on the pricey side @ £106 pluss the vat for the two.
More so, I would like to see the quality before forking out that much.
Does any one know were else to try or who might have a set of original cast ones
secondly
