CompoSimmonite
- Werrington, Staffordshire Moorlands.
I have a 9' x 18' concrete garage with pebbledash finish that I had new in around 1987/88 ! The panels are still perfect but the wooden frame that supports the 8' wide up and over door is starting to rot. This 6" wide frame either side is covered by mock brick effect concrete panels.
I intend changing the up & over door to a homemade tri-fold. Each section of the new door will be angle iron (probably 50x50x3) rectangle with an infill or tongue & groove timber. Not sure yet whether to have one section attached to a new frame pillar and other two sections on the other pillar or to have all three on one pillar.
The new frame pillars will be either I or C profile as I don't want to use hollow section. They will then be covered with cement sheet and clad in slip bricks to duplicate the effect of the original panels.
There will be a smaller I or C profile on top joining the two pillar together.
Question is what do people recommend for pillars - I or C profile and what size ?
Cheers.
Paul
Cheers.
Paul
